The 9 principles of the Residential Measurement Standard (RMS)
RMS is the standard for how residential properties are measured and listed across Canada. This guide covers the 9 core principles in a scannable reference format, with practical notes for each, and an FAQ section built to answer the questions agents and photographers ask most.
Why getting square footage wrong is a listing liability
When a listing's square footage is wrong, or calculated differently than a buyer expects, the consequences range from a damaged relationship to a legal dispute. The Residential Measurement Standard (RMS) exists to prevent that. It defines exactly how residential properties in Canada must be measured and reported, so that agents, buyers and brokers are all working from the same set of rules.
RMS is mandatory in Alberta, where it was first introduced by RECA. For agents listing properties today, understanding the nine principles is the foundation of a listing you can stand behind.
What is RMS and do you need to care about it?
Before RMS, measurement inconsistency was a quiet liability across Canadian real estate. Two agents measuring the same property could arrive at meaningfully different numbers depending on how they handled basements, sloped ceilings or attached walls. Neither would necessarily be wrong under the rules that existed at the time.
RMS replaced that ambiguity with a single framework. Under RMS Ontario, all licensed agents, brokers and associate brokers must use one consistent system of measurement. The competency of anyone providing measurement services (including real estate photographers) is evaluated based on their training, the tools they use and their track record of measured properties.
The 9 RMS principles, and what they mean for your listings
Each principle addresses a specific measurement scenario that comes up regularly in residential listings.
Getting RMS right, every time
iGuide generates accurate floor plans and precise measurements from a single scan, satisfying both RMS and ANSI Z765-2021. The measurement question is answered before you leave the property.
See how iGuide produces RMS-compliant floor plans from every scan. → Explore Floor Plans
Frequently asked questions about RMS
Does RMS apply to condominiums?
RMS does apply to condominiums, but with an important distinction. RMS for condominiums uses interior wall measurements (paint to paint) rather than the exterior measurements used for detached properties. The RMS area for a condo unit is not the same as the registered condominium unit size. These two figures will typically differ and should be presented separately in the listing.
How is below-grade space treated under RMS?
Under RMS, below-grade space, including finished basements, is excluded from the RMS total. It can be measured to the same standard and reported separately as below-grade living area. A fully finished walkout basement adds real value to a listing — RMS just requires it be disclosed clearly as below-grade rather than folded into the headline square footage.
What happens if a listing doesn’t comply with RMS?
When a listing doesn't comply with RMS, it creates legal and professional risk for the agent and brokerage. If a property is listed with inaccurate square footage that does not meet RMS principles, the agent and brokerage may face complaints, fines, or liability if a buyer relied on the measurement in their purchase decision. Consistent use of a compliant measurement system is the most straightforward way to manage this risk.
Are open-concept spaces and vaulted ceilings included in RMS area?
Open-concept spaces and vaulted ceilings are not included in the RMS area. Vaulted ceilings and two-storey voids have no floor space and are excluded from the RMS total. Stairwells with open areas larger than the actual stairs and treads are also deducted. Only areas with usable floor space at the applicable ceiling height thresholds count toward gross living area.
Does iGuide produce RMS-compliant floor plans?
iGuide does produce RMS-compliant floor plans. iGuide's camera system and processing pipeline generate floor plans that satisfy both RMS and ANSI Z765-2021. Every scan delivers accurate floor plans with precise measurements, which means agents and photographers who use iGuide get RMS-compliant output as a standard part of every property documentation package — without manual measurement or additional steps.
Can a real estate photographer deliver RMS-compliant measurements?
A real estate photographer can deliver RMS-compliant measurements when they use equipment and software that produce RMS-compliant output. Under RMS, the competency of a measurement provider is evaluated based on their training, the number of properties they have measured, and the tools they use. Photographers using iGuide produce measurements that meet the standard automatically, making them a reliable and defensible source of RMS documentation.
What’s the difference between RMS and ANSI Z765?
The difference between RMS and ANSI Z765 is that RMS is the Canadian residential measurement standard, originally developed by the Real Estate Council of Alberta, while ANSI Z765 is the American equivalent for single-family residential properties. The two standards share many principles but are not identical. iGuide measurements satisfy both RMS and ANSI Z765-2021, which matters for cross-border listings or properties benchmarked against US standards.
