New partner spotlight: Mediatask
Listing on Funda requires a BBMI-compliant building area report and a Floorplanner floor plan. Through our partnership with Mediatask, your existing iGuide capture now produces both. No new workflow, no extra vendors and no second site visit. Here's how the whole process works.
Delivering BBMI Reports and Funda-Ready floor plans for iGuide customers in the Netherlands
If you're an iGuide customer in the Netherlands, preparing a property for Funda just got easier.
We're excited to announce a new partnership with Mediatask, giving Dutch photographers a streamlined path from iGuide capture to a Funda-ready listing. Through this partnership, customers can use their existing iGuide project to generate a BBMI-compliant building area report and a Floorplanner floor plan—two key deliverables required for publishing properties on Funda.
"The Dutch market has clear compliance requirements for property listings, and iGuide should be the most complete solution for photographers serving that market," says Skylar Lawrence Label, Vice President of Growth at Planitar Inc., makers of iGuide. "Combining iGuide's accurate and immersive deliverables with Mediatask's reporting workflow gives photographers a faster, cleaner path from scan to live Funda listing, without adding complexity to their on-site routine."
Built around your existing workflow
"iGuide performs exactly as needed to create the BBMI report," says Piotr Piadłowski, Co-founder of Mediatask. "We tested the workflow thoroughly before this launch. Photographers don't need to change anything about how they capture a property."
You don't need to learn a new capture process or change the way you work.
Capture the property with iGuide as you normally would. Once your project has processed, download your deliverables (including the SVG floor plan) and upload them to Mediatask. They prepare your BBMI-compliant building area report and your Funda-ready Floorplanner floor plan.
The only additional on-site measurement is room height beneath sloped or complex ceilings. Everything else comes out of your standard iGuide capture.
What this means for your business
Every Funda listing needs a BBMI report and a Floorplanner floor plan. Someone is supplying those today, and until now it usually wasn't the photographer.
Now it can be. You're already on site. You're already capturing the data the report requires. Adding the compliance deliverables keeps the whole listing with one provider: you. That's a simpler story for your agency clients and a stronger quote for every property you shoot.
Why the measurements matter
BBMI is the Dutch compliance standard for building area reporting, based on the Meetinstructie. It exists because buyers make decisions on listed area, and disputed square metres turn into disputed sales. Funda requires a compliant report before a listing goes live.
That makes measurement accuracy the foundation of this whole workflow. iGuide captures a property with lidar at 0.5 percent or less typical distance measurement uncertainty. Mediatask validated the workflow before launch and confirmed that iGuide data meets the accuracy requirements for BBMI compliance.
For you, that means no second site visit and no re-measuring by hand. The data you already capture for the tour and floor plan is the same data that produces the compliance report.
From one site visit, iGuide customers can now produce everything a Funda listing requires.
One capture, a complete property record
An iGuide is a complete property dataset combining imagery, measurement and floor plans. This partnership extends what that single capture can do.
From one visit, you now walk away with:
- A 3D virtual tour for marketing the listing
- Accurate floor plans buyers can actually read
- A BBMI-compliant building area report
- A Floorplanner floor plan formatted for Funda
All details in one place. No juggling separate providers for the tour, the plan and the paperwork, and no chasing turnarounds from three vendors to complete one listing.
Mediatask has the expertise and track record to handle BBMI reporting at scale.
Who's behind the reports
Mediatask has spent 14 years drafting for the Dutch market, including 14 years as a Floorplanner partner, and has reported on more than 300,000 properties. Every BBMI report is prepared by their team of 120 European engineers and personally reviewed by a senior engineer before delivery.
Submit your first project
One scan now covers the tour, the floor plans and everything Funda requires.
To celebrate the launch, iGuide customers receive 15% off Mediatask processing through October 2026. Media Task invoices you directly, separate from your Planitar account.
Head to Mediatask to submit your first project, then follow our Help Center guide for step-by-step instructions on preparing your iGuide deliverables.
