This workflow is available to iGUIDE Pros in the Netherlands only.
Listing a property on Funda requires two compliance deliverables: a BBMI-compliant building area report and a Floorplanner floor plan. Through iGUIDE's partnership with Mediatask, Dutch iGUIDE Pros can produce both from a single scan.
This article covers what to do on-site, how to submit to Mediatask, and what you'll receive back.
- What Is BBMI?
- What You Need to Do On-Site
- How to Submit to Mediatask
- What You Receive Back
- Important Notes
What Is BBMI?
BBMI is the Dutch compliance standard for building area reporting, required to activate a Funda listing. Mediatask has validated that iGUIDE LiDAR data meets the accuracy requirements for Meetinstructie (BBMI) compliance.
Your iGUIDE capture process doesn't change. The only additional step is measuring room heights under sloped roofs — iGUIDE captures everything else automatically.
- Scan the property with iGUIDE as normal
- Measure room heights manually under sloped roofs (that's the only extra step)
- Download your iGUIDE deliverables — SVG floor plan included
- Upload to Mediatask
Once your scan is complete, download your iGUIDE deliverables — including the SVG floor plan — and upload them directly to Mediatask at mediatask.co. When placing your order, you can choose from three options:
- 2D drawings + BBMI report
- 2D + 3D drawings + BBMI report
- 2D and 3D floor plans only (no report)
For questions about submitting projects or Mediatask deliverables, contact Mediatask directly at contact@mediatask.co.
For questions about capturing with iGUIDE, downloading deliverables, or using the iGUIDE Portal, contact iGUIDE Support.
Mediatask returns:
- A BBMI-compliant building area report, meeting Meetinstructie requirements
- A Floorplanner floor plan formatted for Funda submission
Both deliverables are required to activate a Funda listing. iGUIDE's direct Funda integration means the full workflow — from first capture to published listing — stays connected.
Billing: Mediatask invoices you directly for their services. This is separate from your iGUIDE account and will not appear on your Planitar invoice.
