Integrating iGUIDE With Floorplanner
Floorplanner is a web-based design tool used by professionals in architecture, interior design, and real estate to create high-quality 2D floor plans and 3D models. By integrating your iGUIDE with Floorplanner, you can transfer floor plans for advanced editing, detailed visualisation, and richer presentation material.
This guide explains what Floorplanner is, what you need before exporting, and walks through the steps to send your iGUIDE floor plans to the Floorplanner platform for enhanced space planning and design work.
Understanding Floorplanner
Floorplanner is a web-based design platform that helps users plan, visualise, and present interior spaces with ease.
Key capabilities include:
  1. Designing and visualising spaces with drag-and-drop simplicity
  2. Adding furniture, fixtures, and architectural elements
  3. Generating realistic interior renders for presentations and marketing
Its intuitive interface and powerful rendering capabilities make Floorplanner a popular choice for space planning and interior visualisation across multiple industries.
Before you Export to Floorplanner
Make sure the following requirements are in place before starting:
  1. Only iGUIDE Standard and iGUIDE Premium packages can be exported to Floorplanner. Please note that iGUIDE Radix and iGUIDE Instant cannot be exported.
  2. You have an active Floorplanner account.
  3. Your iGUIDE is published and accessible. The iGUIDE must not be locked or expired, as this will prevent a successful export.
Exporting an iGUIDE to Floorplanner
The Floorplanner Export feature transfers iGUIDE floor plans to Floorplanner.com for advanced editing and visualisation.
To export your iGUIDE to Floorplanner:
  1. Click the Floorplanner button located in the left-hand menu of your iGUIDE interface to open the Export Tool
  2. Use the drop-down list to choose the building you wish to export, then click the blue Export button
  3. Verify the property address to ensure you are exporting the correct iGUIDE, and confirm the export when prompted
  4. Log in to Floorplanner using your credentials when redirected, or sign up if you do not yet have an account
  5. Once authenticated, the selected iGUIDE View will be exported, and a green confirmation message will appear when the process is complete
  6. Click the "here" link in the message to view your finished Floorplanner project
Note: You may see error messages within the green confirmation box. These typically indicate data elements that Floorplanner could not translate due to technical limitations. They are known issues and generally do not affect the core functionality of the exported project.
