iGUIDE offers a fast, cost-effective solution for capturing spatial data and producing reliable 2D floor plans with DWG output. It supports architects, engineers and construction professionals by improving accuracy, reducing site visits and enhancing remote collaboration on design and planning work.
This article explains the iGUIDE DWG Floor Plan output, the packages available for architecture and remodel, common use cases and important notes about how the platform handles privacy and measurement standards.
- What iGUIDE DWG Floor Plan Output Is
- iGUIDE Packages for Architecture and Remodel
- Use Cases
- Important Notes
iGUIDE DWG Floor Plans are 2D architectural drawings generated from spatial data captured using the iGUIDE PLANIX Capture System. The plans are delivered in DWG format, allowing professionals to integrate them directly into CAD workflows for design, planning and documentation.
The following iGUIDE packages and add-ons are best suited for architecture and remodel projects:
- iGUIDE Advanced Drawing
- AutoCAD DWG Floor Plan add-on
- iGUIDE Radix
- Reflected Ceiling Plan add-on
- Exterior Elevations (DWG) add-on
- Roof Plans (DWG) add-on
- 3D Model (DWG or RVT) add-on
Use Cases
iGUIDE supports a wide range of architecture, engineering and construction workflows:
- Architecture and design — quickly generate as-built drawings and design layouts
- Engineering — measure thousands of points instantly for precise planning
- Construction — plan equipment placement and safety routes without site visits
- Project management — collaborate remotely with stakeholders using accurate visuals
- Documentation — maintain a permanent visual and dimensional record of spaces
Keep these points in mind when using iGUIDE for architecture and remodel projects:
- The Default View uses a unique URL that does not include the property address
- The Default View is not indexed by search engines, so the 3D tour link will not appear in search results when someone searches the address
- The Default View will be set to "Protected" once published
- The Default View is not discoverable on the iGUIDE Map
- RMS is the measurement standard used for Canada and other areas
- ANSI is the measurement standard used for the United States
- The iGUIDE PLANIX Capture System is required for data capture
- DWG files are based on 2D floor plan data, not full 3D models
- Internet access is needed to view and share virtual tours
- Accuracy depends on proper capture technique and calibration
Q: Can I use iGUIDE DWG files in AutoCAD?
A: Yes, DWG files are compatible with most CAD software.
Q: How long does it take to receive the DWG files?
A: Typically within 48 hours of data submission. This is dependent on the property size and complexity
Q: Is this suitable for large commercial properties?
A: Yes, iGUIDE is scalable and effective for both residential and commercial spaces.
